Replacement for USA import Leaf's Telemetry unit
Startet av Paqo, onsdag 22. mai 2013, klokken 14:42
Paqo
Hi!
There are working to make a unit that will work with a Leaf as well so you will be able to control your car remotly just like CARWINGS works. All you will need is a M2M sim card (https://netcom.no/bedrift/tjeneste/m2m-tjenester) from Netcom for example with fixed IP address.
How many of us would like to have this unit.....maybe this will make progress faster :)
more details: http://www.openvehicles.com/
Ingebrigt
Interested.
How open is this system, can I set up my own server for it, is the hardware specification open for modification?
How much data-traffic will this generate in 'normal' use?
Hejduk
I have already bought the hardware for openvehicle. Definitivly interested in support for Leaf.
2021 Model 3 LR blå
2021 Model Y LR hvit
2019 Model 3 LR grå
2018 Hyundai Kona grå
2017 i3 protonic blue
2012 US Leaf LS rød
2002 Saxo hvit
Balrog
Tesla S P85 2013, Tesla Model S 75D 2017, VW E-Up 2020, Renault Zoe 2017, Hyundai Kona 2021, MG ZS EV 2020
Energica Experia elektrisk MC 2023, Zero SR elektrisk MC 2017
thoru
Sitat fra: Hejduk på onsdag 22. mai 2013, klokken 16:31
did you buy this without the support for leaf?
thoru
Hejduk
Sitat fra: thoru på onsdag 22. mai 2013, klokken 21:17
Yes. I planned to try to contribute to the software, but didn't have any luck with running the development envir. On windows, and I'm not a Linux fan....
2021 Model 3 LR blå
2019 Model 3 LR grå
2012 US Leaf LS rød
2002 Saxo hvit
Ronny
el-Clio -97
I-MIEV -11 Solgt
Leaf -12
Rav4_EV
I'm not sure that all understand how this development works.
There are no company that you can "push" to make progress for Leaf support faster.
This is an open source project. It means that if you and me helps out in the development so we have some code to share.
First of all somebody has to "discover" all the CAN bus messages that are relevant.
For example "Start climate control" or "Read SOC".
Preferably done by "sniffing" can messages on a working car when you activate remotely  "Start climate control".
Just looked into the Git repository. There are no functionality made for Leaf yet.
22' X Plaid
Hejduk
There is a lot of good work regarding can bus messages in the mynissanleaf forum. One obstacle with Leaf is that it has three different can busses. There is an empty framework created for Leaf on the Git hub, but it need someone quit knowledgable to program the software.
2021 Model 3 LR blå
2019 Model 3 LR grå
2012 US Leaf LS rød
2002 Saxo hvit
Rav4_EV
Leaf's Telemetry unit is only connected to one can bus. I don't see the need to connect a replacement to more buses.
Haven't seen any information about the needed can bus codes for remote control on the mynissanleaf.com forum.
If "Hejduk" tells me where to find them I might spend some time writing proper software.
22' X Plaid
Ingebrigt
If you want to add functions as well as replace the telemetrics it might be neccesary to use more than one bus.
Rav4_EV
Sure. Especially if you want to know the cars speed or steering angle when it's parked ;D
22' X Plaid
Paqo
Sitat fra: Rav4_EV på torsdag 23. mai 2013, klokken 23:34
Is there a way to reprogram telemetry (Leaf from US) unit to work in Norway ? cause I guess changing a sim card for a M2M one will not help.....
Ingebrigt
#14
;D
You need to upgrade your imagination. One might want to be able to lock/unlock the car, or check the temperature of the battery. Heck, if you install the correct hardware, and trust the server, you can replace the key fob with your phone.
