BYD Tang med refreshed design og større batteri
Startet av Blitz, onsdag 10. november 2021, klokken 20:13
Blitz
The most prominent design change is in the front of the vehicle which now comes with a more modern-looking, minimal grille . This year's model featured a grille that occupied a larger part of the front of the EV but the newer design comes with a smaller one with chrome trim. The newer grille also holds the "Tang" car logo.
Apart from this, the rest of the body hasn't been changed much. The rear and sides of the vehicle are almost indistinguishable from its older model, although the body length has been increased slightly. As such, the length, width, and height of the new BYD Tang EV are 4900mm x 1950mm x 1725mm, respectively, while the wheelbase stands at 2820mm.
Moving on to the SUV's engine, it is an electric motor with a power of 168kW (approximately 229 horsepower). The power has in fact been reduced when compared to the current single-motor version of the Tang EV. However, a dual-motor four-wheel-drive version is expected to be launched soon to compensate.
The lithium iron phosphate Blade Battery of the new BYD Tang EV has been upgraded with an increased density, rising from 140wh/kg to 150wh/kg, which is a considerable upgrade. Because of this, the battery life/range of the vehicle will be reaching 700 kilometers.
Current BYD Tang EV models on sale are three in number, namely long-range, four-wheel-drive high-performance, and four-wheel-drive high-performance flagship.
The newer model will be replacing the current single-motor variant and is set to be unveiled at the Guangzhou Auto Show on November 19.
https://www.gizmochina.com/2021/11/10/byd-tang-ev-announced-with-a-new-design-and-700km-battery-range/
Dagens Tang med firehjulsdrift har vel en NEDC rekkevidde på 500 km, så med det nye batteriet bør vel rekkevidden øke til 600-650 km NEDC og 500 km WLTP.
JorgenM
Trist at de fjerner grillen fra dagens versjon. Den nye ser desverre langt mer Kina ut. Jeg har avventet kjøp pga ryktene om oppgradert rekkevidde, men ble litt skuffet nå. Vi får se 19. november da.
Vaduz
Likte den nye grillen mye bedre, digre griller er veldig gammeldags på en elbil synes jeg. Med såpass rekkevidde kan den faktisk bli aktuell etterhvert, særlig om man kan fjerne drømmebygger bokstavene bakpå!
Sitat fra: Vaduz på torsdag 11. november 2021, klokken 16:57
Den teksten er litt som å ha Home Sweet Home på veggen hjemme  ::)
Sitat fra: JorgenM på torsdag 11. november 2021, klokken 04:38
Var det noen som sa "Voldemort"?
Kjell Leaf
Rekkevidden blir langt fra det som noen antyder her. 700 km nedc tilsvarer sannsynligvis i underkant av 600 wltp. I tillegg er det single motor som omtales ger, og forskjellen mellom 2wd og 4wd bruker å være ganske stor. Jeg tipper rundt 500 km på 4wd.
Leaf Tekna, levert des. 2013.
Farge : Hvit
J0kerN
«The newer model will be replacing the current single-motor variant and is set to be unveiled at the Guangzhou Auto Show on November 19.»
Dette skjedde vel ikke?
Blitz
Bilde av den "nye" Tang, synes fronten ser bedre ut uten grill.
MyMuffin
Ser ut som at 2022 varianten får ett 108.8 kwh stort batteri, det er i så fall ett meget godt steg opp og da bør vel 500km real world rekkevidde være oppnåelig.
Kilde: https://topelectricsuv.com/news/byd/byd-tang-ev-norway/
2024 Model 3 LR Highland
2022 Model Y (familietralla)
2021 Model 3 LR - Solgt i 2023
2019 Model 3 Base Perf - solgt i 2021
2019 Model 3 LR - konebil - solgt i 2022
2017 Model S 75D - solgt i 2019
2014 Model S 60 - solgt i 2017
torlie
2020: MG ZS EV
2018 Zoe Bose Edition (solgt)
2016 Zoe Intens (Solgt)
edyrli
Da kom omsider faceliften av Tang. Jeg kommer ikke til å løpe til nærmeste RSA forhandler og oppgradere, men den har fått en grei oppgradering av batteriet. Rekkevidden har økt fra 400 til 530km og hurtiglading fra 110 til 170. (Jeg får som regel 119kW)
Så var det dette med prisen da. Man får mye fint til 699.900... Men om man må ha 7 seter så står den jo greit i forhold til andre SUV med 7 seter.
https://byd.no/modeller/tang-4x4
2021 BYD Tang
2020 SEAT Mii Electric
1996 Suzuki LS-650 Savage
Svk
Er jo ikke noen ny bil,bare en oppgradering.
Sliter med å lade det batteriet jeg har idag hjemme.
Men på tur er det jo gull med nye batteriet sammen med raskere lading
Men var jo i danmark/tyskland med 400wltp.er egentlig mer enn nok...
Eneste som frister er Dynaudio
Suverin
Noen som vet om de har fikset så man kan lade nye Tangen på v3 og v4- superchargers?
Kjører Solterra og Model 3.
«Can the Solterra Subaru? - Holy shit! Yeah! There is absolutely no reason not to go do Subaru stuff in the Solterra!»
Svk
Sitat fra: Suverin på mandag 07. oktober 2024, klokken 12:58Noen som vet om de har fikset så man kan lade nye Tangen på v3 og v4- superchargers?
BYD Dolphin, BYD Seal 4×4, BYD Seal U og BYD Tang 4x4 Long Range kan lade på alle Tesla sine ladere. Når det gjelder BYD Tang 21-23, BYD Han og BYD Atto3, kan disse lade på Tesla sine V2-ladere. Flere eiere har uttrykt ønske om å kunne lade disse modellene på Tesla V3/V4, noe vi ved flere anledninger har videreformidlet til fabrikken. BYD har jobbet for å finne en løsning på dette, men vi har nå mottatt endelig informasjon om at dette dessverre ikke vil bli tilgjengelig på nåværende modeller, grunnet mangler i bilens hardware-konstruksjon.
Hansi
Har de sagt noe om hvilke mangler i bilens hardware-konstruksjon?
Buskerud
