Skjult service meny
Startet av GelpMan, fredag 10. oktober 2014, klokken 09:55
GelpMan
Har klippet og limt dette fra BMW-i3 sin Uoffisielle facebook side.
Vet ikke om dette fungerer på Europeiske modeller.
Har ikke testet selv ennå da kona har bilen, prøver senere ;)
Hidden Service Menu on Instrument Cluster
To enter the menu, hold down the trip meter button on the side of the instrument cluster screen for 10 seconds. From then on, pressing this button means "next" and holding down the button means "select".
To begin with you have only these options available:
1 Identification
    1.01 Conv. Index (1/mls)
    1.02 SWFL 1
    1.03 VIN
    1.04 HMI Version
2 System test
3 Start roller
10 Unlock
To unlock the following menus, you will need the VIN from 1.03 above. Add the last FOUR digits together (other BMW models require adding the last five digits) to get your unlock code. e.g if your VIN is L12345, your code is 2+3+4+5=14. If that doesn't work, try adding the last five digits.
11 Consumption
11.01 Consumption dist. (l/km)
11.02 Consumption time (l/h)
12 Range
12.01 Range consumption (l/100km)
12.02 Range (km)
13 Fuel Tank/Battery
13.01 tank left (ohm)
13.02 tank right
13.03 tank left (litres) - zero
13.04 tank right  7.9l
13.05 tank total
13.07 display value
13.07 tank phase. 1
13.08 Batt. Kapa. Max.  19.8 kWh (maximum designed battery capacity)
13.09 State of charge
13.10 Batt. Ladung (battery charge)
13.11 Batt. Anziege (battery meter indication)
14.01 O. Temp. Sensor
14.02 O. Temp. Raw data
14.03 coolant temp
14.04 oil temp
14.05 batterietemp
15.01 litre counter
15.02 time counter
15.03 distance counter
15.04 kWh-Zaehler ("kWh counter")
16.01 v CAN (km/h)
16.02 v Display (km/h)
16.03 Cruise Control (km/h)
16.04 Rev. Counter (1/min)
17 System Voltage
17.01 Ubatt (V)
18 Accoustics
19 DTC
20 Dimming LCD
20.01 LCD temp. Sensor (ADC)
20.02 LCD temperature (C)
20.03 Light sensor
20.04 LCD luminance
21 Dimming PWM
21.01 Dimming wheel
21.02 Display
21.03 Scales/pt. orange
21.04 Underfloor pointer
21.05 Status lights
21.06 Status lights blue
22 CBS (condition based service)
22.01 km/year short term (km)
22.02 service call status
22.03 Limit, time (Month)
22.04 Limit, distance (km)
23 Check
24 Correct. Factor (careful!)
25 software  reset
GelpMan
#1
Fikk opp to bilder. Gikk ikke videre, turte ikke det.
haggen
Hvordan får du lagt inn unlock koden da?
Bmw i3 2014-2017
Volvo V60 plinn hybrid 2017-2020
Mercedes EQC AMG Edittion Juni 2021
LMOR
Som jeg skrev i en annen tråd er oppstarten feil beskrevet.
Du holder inne knappen mens du trykker på start. Da ser du den riktige menyen vises så vidt. Da kan du slippe knappen og vente til menyen kommer frem. Tar ca 10s.
Menyen det er bilde av her er ikke den riktige. Den kommer frem hvis du gjør det feil  ;)
2023 BMW iX1 SuperCharged
moonbuggy
LMOR:
Din metode funker hver gang. Før du beskrev den, kjørte jeg 10 sekunders metoden beskrevet av GelpMan. Jeg fant aldri helt ut av det, men den ga meg både "Reset Menyen" over, og "riktig "service" meny. Jeg fant aldri noe system i hvorfor jeg fikk hva jeg fikk, men fikk alltid opp riktig "service" menu enten 1. gang eller etter diverse forsøk.
Med "reset" menyen kan du resette service og bremsesjekk til "nåværende måned" to år frem.
LMOR
Me too. Tilfeldig at jeg oppdaget det. Alle beskriver den tungvindte måten.
Eller tror jeg jeg fant mønsteret, men en gang du skrur på blir noen av lysene orange, for så å bli rød. Hvis du trykker mens det er orange, går det greit. Hvis det blir rødt, så kommer feil meny.
Men uansett er "min" måte enklest og sikrest  ;D
bromm
Sitat fra: GelpMan på fredag 10. oktober 2014, klokken 09:55
Dette er FEIL - det er altså de 5 (FIVE) siste i VIN som skal summeres !!!
LMOR
Han som skrev det hadde sikkert 0 i første :-)
Mener jeg leste at det kan være 4 hvis summen av alle 5 siffer er høyrere enn du kan legge inn? Vet ikke om det stemmer.
Olemann
Prøvde metoden med å holde reset inne mens jeg startet, og fikk da opp nye valg, 2 stk pr skjermbilde, som scrollet fram til 2 nye valg når jeg trykket reset igjen.
Mener huske det var identification, reset, service og endel andre, men turde ikke gå videre og heller ikke info om hvilke knapp som skulle brukes for å velge.
Forsvant heller ikke, så nå står de fast som 2 nye valg på skjermen.
LMOR
Dette er på egen risiko. Du veksler med å trykke kort inn, og du velger med å holde den inne.
Det fryser ikke fast for godt :-)
TorS
Sitat fra: Olemann på lørdag 28. mars 2015, klokken 20:18
Samme her. Ble litt heit i toppen når de ikke forsvant. Gikk inn igjen på service menyen og valge End Test el.l., da forsvant de.
iX3 fra 24.03.2021.
i3 fra 29.10.2014. Solgt 20.1.2021.
Ålesund.
LMOR
Det er bare å skru av bilen også. Neste gang du starter (minst 10-15min) er det borte.
moonbuggy
Sitat fra: LMOR på lørdag 28. mars 2015, klokken 20:06
Sikkert riktig, fordi "telleren" man kan taste opp for tverrsummen går opp til 35, for så å starte på null igjen.
moonbuggy
Sitat fra: LMOR på lørdag 28. mars 2015, klokken 22:31
Hos meg blir menuen nå borte så snart jeg tar en restart.
Men, for all del, exit fra de blinkende avlesningene først(hold inn tripp knappen lenge nok). Slo av bilen en gang midt inne i en avlesning av battery temp (den oppdatetes jevnlig, displayet blinker for hver ny oppdatering, ca 0,5 sek.)
Det resulterte i blinkende felt på skjermen i flere timer etterpå, selv om jeg prøvde å slå av og på bilen med jevne mellomrom. Først neste dag fungerte det igjen.
LMOR
Av og til er du heldig og det blir borte med en gang.
Hvis du blir stuck, og skal/må kjøre, så hjelper det ikke å skru av/på. Da må du ut av menyen, eller hvis du ikke får det til eller vil bruker til på å finne menyvalget:
Skru av og så på igjen, og trykk inn knappen litt senere, slik at "Feil meny" på bildet over kommer fram. Når du da skrur av, så er alt som normalt igjen.
