Sv: Din Model S levering.
Startet av Poppe, onsdag 23. oktober 2013, klokken 13:40
Poppe
Heres a picture of where the VIN number is supposed to be according to the user manual, as you can see there is nothing there (windscreen bottom left corner).
Where should I be looking for it instead ?
Chevy Volt -12
Th!nk City -99
Th!nk City -08
Peugeot 107 -07
Chevrolet Corvair Convertible -64
Chevrolet Rampside Pick Up -61
Renault Kangoo 4x4 -05
i Göteborg
BauDemo
on 2 other places:
- on the cooling radiator - there should be a yellowish label
- under the passenger seat - pull the seat in most forward position and look at the floor for a cut. Open the cut and you will see it stamped in the metal.
Poppe
Sitat- under the passenger seat - pull the seat in most forward position and look at the floor for a cut. Open the cut and you will see it stamped in the metal.
Just like the old Think then.
I will check this afternoon.
Chevy Volt -12
Th!nk City -99
Th!nk City -08
Peugeot 107 -07
i Göteborg
