Sv: Hvor mye overlading er normalt?
Startet av BauDemo, torsdag 12. juni 2008, klokken 18:28
BauDemo
This morning I noticed that the "ventilation air direction" dial is not really working - this is the dial that is on the left hand side. The air is blown at the windshield with no respect to where the dial points. After some back and forward switching, something fell off from a whole in the dash... I am attaching an image of it....
Is this easy to fix, any suggestions before I dig myself in the dashboard?
Ken
Sorry  Bau Demo, no one seems to know. Is this a spring metal clip to fix a metal rod to a flap or something ? This is the worst type of job for someone with a bad back. To lie under a dashboard with ones feet in the air trying to get at some inaccessable part mixed up with a load of wiring. Give up and buy a new Think!
cra
What is this "give up" thing you speak of?  ;)
I just had a look under my dashboard, and I found out where that clip belongs. It's located right under your radio, and with a flashlight you can see it from under the dashboard. Don't try if you have a bad back!
This clip holds the cable sleeve from the flow selector, not the selector itself. The problem is that if the sleve isn't fastened, it moves with the cable, kind of like the gear or brake cable on a bike.
If the clip isn't damaged, you should be able to reattach it like on the picture I attached. The problem might have come due to a rusted/stuck cable, so try WD40 or something like that in the cable. You might be able to reach it from above if you remove your radio. I didn't remove mine.
1 on the picture is the clip
2 is the fuse on the back of my radio.
The white flat surface is facing down; i took the picture from an odd angle.
Tesla Model S75D 30/6/17
Leaf 9/5/12
Sykkylven (Sunnmøre)
Et glitrende eksempel på internetts fortreffelighet.
Hadde en lignende sak me Lancia Delta Integralen. Der var styreslangene for wastgate ventilen feilkoblet, og en i England så dette. Dermed ble problemet løst.
BauDemo
Thanks alot for all the info. I will check my back first :), then lie down and try to put the spring back. Will do some pictures in the process for the archives, and let you know the result.
BauDemo
Finally! It is all working again... ;D
Initially I tried putting the brace back from the under side.. but it did not work for me... I think the cable had very hard time moving in the sleeve. This probably was the reason for the bracket to pop out in the first place. So I did remove the radio and used some wd-40 spray on the cable...
It took two weeks before I could again pay some attention to it... the cable was now moving very smoothly in the sleeve, and I did not have any problems with the bracket.
On a side note - I did manage to get my personal record - 90.1km on one charge... this is with the radio not mounted... I wonder if it is my heavy foot while listening to music, or if the radio is drawing a lot of power even when the car is off...
Thank you again for all the information - it would have been very hard for me to figure this out on my own!
Sitat fra: BauDemo på tirsdag 15. juli 2008, klokken 22:43
Many connect the Yellow "light" cable to permenent +. It thats the case on a electric car, the DC/DC will have a lot of work, and will drain your traction battery.
BauDemo
thanks elektrolux!
hmmm... yellow... I am attaching here two photos of the connection on the back of the stereo... which one would be the offending one?
cra
I think (no pun intended) you can just use a multimeter to check the pins on the plug to see which one gives 12V when everything is off. If the radio uses this it will drain the 12V battery, albeit slowly.
Leaf 9/5/12
