Which biltema coolant is compatible?
Startet av BauDemo, fredag 19. april 2013, klokken 22:02
BauDemo
I need to top up the coolant and am wondering which of the coolants available at biltema are compatible with the original coolant?
Here are the 3 I found:
http://biltema.se/sv/Bil---MC/Bilreservdelar/Kylsystem--Ventilation/Kylare/Glykol-fardigblandad-36703/
http://biltema.se/sv/Bilvard/Spolarvatska-och-Glykol/Glykol-longlife-fardigblandad-36705/
http://biltema.se/sv/Bil---MC/Bilreservdelar/Kylsystem--Ventilation/Kylare/Glykol-longlife-361783/
From the manual - the original coolant is
"All Vehicle 50/50 antifreeze/coolant from Prime"
Rød og blå Glykol er kompatible.
Orange longlife er ikke kompatibel med vanlig Glykol som var oppi min nye Think
Arnie
Trondheim. Elbilist siden aug 2001. Think Classic, nå City (korte turer), BMW i3, Tesla X90D (lange turer og gratis strøm).
BauDemo
BauDemo
Ok - I thought I should share and maybe save someone a lot of trouble.
Last time I ended up buying some coolant from a autoexperten and it was supposed to be compatible...
Now for another Think I need to fill in some coolant and decided to get to the bottom of this.
According to the manual the coolant in the Think is "Statoil" coolant.
The manual states:
"THINK City comes from the factory with a 50% blue coolant from Statoil. Refill with the same brand."
Now from the statoil website the only blue coolant I find is this one:
https://external.statoilfuelretail.com/mar/svg01184.nsf/design/lub_pds/$file/propylenglykol.pdf
Notice that this is "propylenglykol"!
And now back to the coolant types available at biltema - all of them have the following text in the description: "Får ej blandas med propylenglykol. Färg: blå."
wow!
More reading and it turns out that the color of the coolant is nothing more than a color - the pigment is making it easier to spot leaks.
So I am going to buy a blue coolant from statoil and fill up... while someone with richer chemistry knowledge can clarify all the stuff above.
Please ignore the content above.
