Lukking av frunk
Startet av 2ris, søndag 27. oktober 2024, klokken 19:19
RN1776
Sitat fra: 2ris på torsdag 31. oktober 2024, klokken 17:31Great. Do you need to loosen any bolt or something like that before you can do the actual adjustment of the rubber knobs, or can you just turn the knobs right away? (I guess clockwise to make it easier to close the frunk)
No prep needed. It turns easily by hand in standard direction, clockwise to shorten
