Think TechCentre
Startet av Warlock, lørdag 04. november 2023, klokken 19:32
trunnion
#75
Sitat fra: Warlock på lørdag 09. november 2024, klokken 15:30Drew Technologies MongoosePro JLR
Beskrivelse: En mye brukt J2534 kabel blant annet mot Jaguar, Landrover, Volvo og Toyota.
Tilgjengelighet: Original fra Drew Technologies til ca 3000,- eller kloner fra Kina (aliexpress) til rundt 200,-
Kommunikasjon: CAN, K-Linje
Fungerer mot: BMI, BMS, CDCM, PCU, SRS, VCU
Driver: Pass-thru-driver lett tilgjengelig på nett hos Drew Technoogies. https://www.opusivs.com/support/product-downloads/ (laaaangt ned)
Eventuelle problemer: Skal ha K-linje, men K-linje tester svarer "Not supported" i TechCentre, så kan ikke kommunisere med ABS, EPHS, og GEM. Fixed, now fully working
Løsning: Ingen løsning (ennå) men går helt fint uten?
Eventuelle tilpasninger:
Endring trengs i "C:\Program Files (x86)\Omitec Ltd\THINK TechCentre\THINKDiagnostics.exe.config" under <appSettings> må "3G VCI" fjernes eller kommenteres ut, og to linjer legges til.
  <!-- <add key="PassThruName" value="3G VCI"/> -->
  <add key="PassThruRegistry" value="Drew Technologies Inc. - MongoosePro JLR"/>
  <add key="PassThruName" value="MongoosePro JLR"/>
Hi Warlock,
Since you brought it to my attention on the Facebook page, I looked into the problem and fixed it. It turns out that there are certain J2534 configuration parameters that are defined in the standard, but not intended to be used:
Think TechCentre was trying to set these forbidden parameters and that made the Mongoose driver very upset. I think other J2534 adapters simply ignore the request, but the Mongoose driver is very strict about error handling.
Anyway, I removed these parameters from TechCentre's database. It should not affect other J2534 adapters, since these parameters were not to be used.
Simply replace the attached file (remove the .ov2 suffix) in C:\ProgramData\Omitec Ltd\THINK Diagnostics\Data\Databases
This directory may be different if you're using Windows 7 or older.
Warlock
 :+1:
Wow! Nice find there. this is just perfect! I'll play around with it a bit and test the cable again (I actually have several versions of this cable, and use t for other cars as well)
Thank you for letting us know about this :)
