Think Gearshift Problem - SOLVED -
Startet av Th!nkJB67, lørdag 19. mars 2022, klokken 13:30
Th!nkJB67
Hallo,
i have a problem with the gearshift.
Sometimes the car won´t start. The shifter is in position P, but the indicator lamp shows N and
the Power Limit Light flashing.
No matter what gear I put in, N is always displayed and flashing.
How can I fix this?
There are some microswitches, but I don´t know which one.
Maybe the shifter is worn and does not hit the right position.
The 12V Batterie is OK at 12,6V.
Here is a video on facebook:
https://www.facebook.com/jorg.biank/videos/1392967454551923/?notif_id=1647710404821085&notif_t=video_processed&ref=notif
The same on yt:
https://www.youtube.com/watch?v=JRH2HWDeZt8
Thank you in advance.
Jörg
Th!nkJB67
It was the most obvious in electronic. A little bit of contact spray to the cable lugs of the microswitches...
https://www.youtube.com/watch?v=AYyZ2AnyYXM
