GreenRace 3 rekkevidde simulator
Startet av BauDemo, onsdag 30. mai 2012, klokken 14:53
BauDemo
Quick post to report back that the airbag program for laptop works with Windows 7. I used a dell precision M2300 laptop with its builtin serial port.
I just cleared an error code in the airbag ecu - my 12V battery went down and the airbag ecu got confused.
Here are some screenshots.
Trond E
Good news. Which cable did you use? I got an active airbag lamp in my car, and would really like to get rid of it
Trond Einar
Sent from my HTC Desire HD A9191 using Tapatalk 2
Sort Th!nk City Zebra 2008 mod
Ex Rød Th!nk Classic 2002 mod
Trondheim
Yeyeye
Good news Nikolay, my light bulb in the airbag lamp is soon worn out :D
Any way this program could be converted for the nikometer?
Arild R
Trondheim
Think classic 2002,Think classic 2001(tidligere Gråtass)
Nissan Leaf 2016 30kWh
BauDemo
I used the "official" Think program. I don't think I will have the time to make similar program for the nikometer.
The nikometer adapter will not work - I used this one http://www.obd2-shop.eu/obdserialrs232kldiagnosticinterfacereadytogo-p-166.html
Bridge (connect together) pin 13 with pin 7 and pin 14 with pin 15 on the adapter.
Trond E
It works with win XP also. I was able to clear the light in my car tonight using the modified cable you recomended. Thanks!
Om det er noen i området rundt Trondheim som har en irriterende rød airbaglampe i bilen, så bare ta kontakt.
Trond Einar
Trondheim
Yeyeye
Du får ta den med på neste møte, jeg trenger i allefall;)
Mvh Arild Rabben
Trondheim
BauDemo
Good to hear!
Sitat fra: Trond E på lørdag 26. mai 2012, klokken 00:29
Trond Einar
hfosse
Does anyone know where I could get a hold of this "official" software? I also have an AirBag to reset :)
hma
#8
Trondheim Thinkers har offisielt kjøpt ut denne programvaren fra Ford (Kverneland Bil) etter at de har avsluttet sin support på bilen.
Jeg mener vi trygt kan legge ut programvaren for nedlasting, enten på forumet eller på elbilwiki, uten at vi forgriper oss på opphavsrett og lignende.
Noen kommentarer? Støtter forumadmin dette?
Kan noen rapportere mitt svar her til forumadmin? (man kan ikke rapportere egne innlegg).
Hilsen
Håkon
- Toyota Rav4 EV 2000 NiMH (06/2010), Tesla Model S75D (12/2018)
   (tidligere: Think Classic 2000 NiCd (06/2009-05/2012) - Think City 2010 Zebra (03/2012-10/2012) - Think City 2009 Zebra (05/2012-05/2014)  - Tesla Model S 2014 (06/2014-09/2017) - Nissan Leaf 2018 LE 40kWh (04/2018-12/2018) )
- Ariens AMP 24 to-trinns snøfreser 48V litium 52,5Ahr (10/2012) - Bosch Rotaks 43 Li-Ion gressklipp
Lars C. Krogenæs
Send en mail til info@thinkev.com og skriv at dere legger ut programvaren på nett, og be Think ta kontakt dersom dette ikke er greit.
Hvis (når) dere ikke får svar, får vi forutsette at dette er greit.
Hvis det er noe igjen av think, bør det være i deres interesse at think bilene holdes på veien.
Mao legg det ut, og legg ut lenke her på forumet.
Lars
Jobber med hjemmelading hos Circle K.
Mars 2017: Leaf 30 kwt
2013-2016: Mitsubishi imiev
2007-2012: Citroen Saxo el
2007: Kewet med NiCd batterier
El rayo
Sitat fra: Lars C. Krogenæs på tirsdag 29. mai 2012, klokken 10:04
Lars
Selvfølgelig er det mange igjen av 1999-2002 Th!nk. Det er siste måneden at Th!nk har falt ned på andre plass blant antall elbiler i Norge.
Lars C. Krogenæs
#11
Sitat fra: El rayo på onsdag 30. mai 2012, klokken 21:46
Lars
... Tenkte på selskapet, ikke de fysiske bilene, som jeg vet det finnes mange av. Vi må alle prøve å bidra til fellesskapet for at de kan fortsette å være på veien.
Lars
Think
Noen som ha en fiks på noe sant?
5 x Think City, Leaf Tekna 24Kw
Ser ut som ignitoren på airbaggen din har gått ut på dato.
Har et "nytt" ratt vi kan prøve. ;)
Freia
Fikk opp Airbag lampen på Th!nk'n ikveld etter antall ganger frakobling av 12 V batteri angående batteripakke arbeid. Ble progammet for sletting av lampen lagt ut ??  :-\
2000-modell TH!NK city PIV 4 (sort).
Startet på 66137 km 1.12.2012 *Kjørt 69900 km*
Volvo 244 GL '78
GMC Vandura '86
