Nicometer i Nye Think
Startet av elektrolux, fredag 17. februar 2012, klokken 12:21
twirk
I have a yellow 2010 Think with zebra battery. Would I be able to use this setup to diagnose my battery charging problems?
Think 2010, med Zebra batteripakke. Farve: City Citrus
bcx238h
Sitat fra: twirk på søndag 20. august 2023, klokken 18:58I have a yellow 2010 Think with zebra battery. Would I be able to use this setup to diagnose my battery charging problems?
Work in progress...but I'm definitely working with diagnostic functions.  ;)
bcx238h
Hello guys!
I have done few small changes in the programcode.
I wrote a lot of comments and changed some variablenames to be more consistent.
The batterypage is displaying the three SoC values, now.
If somebody want to take a look, I uploaded the zip-file. Just change the extension from .txt to .zip as usual.
Aside from that I uploaded a pdf-file. It's a scan of the original Nicometer with some extra informations and a lot of comments/explanations.
Perhaps some of you always wanted to know more about the program structure and so on.
The autorun.bas in the zip-file can be opened with the normal texteditor, too.
There are a lot of comments/explanations, too.
Remember that I use a joystick with x- and y-axis and button to move around. The program is a little bit different.
ZEBRA-battery-drivers have to change the variable "_is_enerdel" to 0. Because of debugging, I change it manually.
I have to logg more telegrams with Savvy-CAN. I want to get more informations from the 16 battery modules. Since my battery is working fine, now, I can concentrate me more on the "Nicometer".  :laugh:
Just two pictures of the Nicometer as it's now...no big differences! *Debug mode with random values*
