Nicometer i Nye Think
Startet av elektrolux, fredag 17. februar 2012, klokken 12:21
cs
#105
Hello guys, we're actually in Norway and brought something with us....
From today on you can order the new Think-O-meter OBD plug and play Display via Elbilhjelpen. Its called the new RoboMeter 306 there.
Kind regards evdriver
Sitat fra: cs på søndag 23. mars 2014, klokken 18:16
Hello
We here in Germany have developed another kind of Data Display for the New Think.
Its based on the BMS from GK-Anlagentechnik (in Norway better known as the Robometer).
We adapted Can readout to the BMS Headunit and wrote some lines of code. ;-)
The Think CAN-Bus Display is still in development, but it exists Version 1.0.
We actually can display Voltage, Current, SOC and Zebra Temperature.
I now have a very practical question:
How did you (the Nikometer users) solve that the OBD plug is under the Fuse department closure, and with OBD plugged in, its no more possible to close the compartment. See pic. Before I make a new closing with an opening for the plug in it, I wanted to ask...
More pragmatic thinkers maybe leave it open all the time but I'd like a more elegant solution.
evdriver
2x Peugeot Scootelec, City EL (running), Th!nk City 1299 returner (sold), Th!nk City Gen2 Zebra EX-Ambulance 2008 1PP-2 Prototype Series, Kewet Citi Jet5
DE-52XXX near Cologne
http://www.thinkers.24.eu/
http://www.evalbum.com/3418
Go-carter
Sitat fra: cs på torsdag 13. oktober 2016, klokken 14:34
From today on you can order the new Think-O-meter OBD plug and play Display via Elbilhjelpen. Its called the new RoboMeter there.
Hello
evdriver
Pictures?  :D
TMX60D
Leaf S 2015
cs
#107
Hej.
I have only a video from an early test https://youtu.be/fHMgeO-v7vU#t=0h8m0s
You will find product pictures in Roborts shop soon. I saw him taking them this morning...
#108
Legges straks ut på nettbutikken, men her er noen bilder.
Plug and play. 1 meny på Zebra med systemspenning, strøm og temperatur, og 2 på Litium versjon med bl.a høyeste og laveste cellespenning. Ble overrasket over hvor jevne fatteren sine celler var etter nesten 80 000 km og null verkstedsbesøk.
Pris 2500.-
Go-carter
Pen løsning, og en helt grei pris for plug-n-play iallefall. :) Synd Think har plassert OBD-kontakten på et så ugunstig sted. Hjalp ARV her på forumet med å montere BauDemo sitt oppsett i går, og selv med vinklet OBD-kontakt lot det seg ikke å få på lokket. Kanskje det går an å skru det ned?
TMX60D
Leaf S 2015
Enig. Det enkleste er enten å flytte diagnosekontakten eller lage et hull like over den.
Warlock
Jeg ville kjøpt en splittekabel (eller egnentlig, jeg har kjøpt en y-kabel fra et kinafirma. Kommunikasjonen var vel o merke svært spesiell). Man kan da skru ned kontakten, og plugge sammen og skru en av y-armene inn ved siden av sikringsboken og a en løs OBDII kontakt henende under klar til mer eller mindre permanent inplugging...
BauDemo
Sitat fra: Warlock på onsdag 19. oktober 2016, klokken 23:42
Har du lust att ladda upp en bild på din lösning?
Warlock
Ikke så lett å ta bilder av installert kabel, men legger ved et bilde av splitterkabelen. Man skrur løs  ODBII pluggen i bilen og slipper den end. Skrur inn den blå kontakten til venstre i bildet i dennes sted, og man ser ingen forskjell (og lokket går på uten modifikasjoner). Original kabel plugges inn i kontakten til høyre. og med noen få strips har man også fått festet dette opp ganske bra. Nå har man en ekstra ODBII plugg under "hanskehyllen" også, den bakerst til venstre på bildet...
God løsning.
Er dette ordinær handelsvare?
Warlock
Ja, jeg bestilte den fra http://www.obd2plugs.com/Product-453.html for noen år siden men som sagt, kommunikasjonen var svært rar, og transporten kostet dobbelt så mye som kabelen, så jeg vil anbefale å bestille opp en liten batch....
Go-carter
TMX60D
Leaf S 2015
Takk. Forespørsel på 5-10 kabler sendt.
thetore
Trondheim:
Reva 2009mod. Solgt.
Think City 2009mod. Solgt.
Think City 2011mod Lithium.
Bmw I3  Fully Charged 2017mod. (29.11.16)
Go-carter
Liker ikke Nikometeret minusgrader? Nå som det begynner å bli kalt ute påstår den at PCU holder 125 grader :p
Og foresten - stemmer SOC? Når bilen sier 30 % sier Nikometeret 39%. har jeg så mye å gå på?
TMX60D
Leaf S 2015
