Energy lost while driving
Startet av Poppe, tirsdag 17. januar 2012, klokken 10:05
BauDemo
The latest charge is a calculated parameter.  So depending on your settings it may not be 100% correct. It also does not include the overcharged Ah.
There was a discussion long time ago, what the latest charge should be, but I can't find it... maybe it was on the old forum?
Poppe
But there is both "Sist Ladet" and "Sist overladet". If you add those, how far off will you be ?
Is there any change of this in the new SW ?
Chevy Volt -12
Th!nk City -99
Th!nk City -08
Peugeot 107 -07
Chevrolet Corvair Convertible -64
Chevrolet Rampside Pick Up -61
Renault Kangoo 4x4 -05
i Göteborg
El rayo
#17
I run v.1.5.1112. What resets the "Sist ladet" parameter to 0? Edit: now I recall, the reset point (at a certain SOC) can be set at the "Delta....Ah" under the "config" screen. The nikometer needs to be connected and set in the BMS mode while charging to get this parameter correctly monitored.
The "Sist overladet" parameter count Ah during the phase 2 (5A) charging only and retsets to 0 after a full charge,  it seems. When I interupt the charging - say at 98% - This parameter continues counting on the next overcharge.
El rayo
There is a lot of interesting reading on the nikometer and water filing at http://elbilforum.no/forum/index.php/topic,2289.30.html
BauDemo
Tack El rayo! Good explanation.
Sitat fra: Poppe på lørdag 21. januar 2012, klokken 12:01
I made two photos where you can see the name of the parameters and some sample values.
First one is at the end of charge from about 25%.
And the second one is after some (6Ah) driving.
Hope this helps.
