Saxo problem
Startet av Niram1969 ., torsdag 26. april 2018, klokken 07:27
Niram1969 .
Saxo Electrique 2003, 46xWB-LYP100AHA LiFeYPO4, 107kkm, 13000kWh used
Björn Nyman
#16
Sitat fra: Niram1969 . på mandag 09. juli 2018, klokken 11:57
(hopefully) Final update:
I have received new chopper board, replaced my (suspectedly failed) one. I started the car and immediately after pressing accelerator, yellow error light appeared. Car would not move. Reason - Permanent fault - Function: drive current chopper.
[attachment id=2 msg=694420]
Before I put my board back in, I took another look at it. And bingo, I found (at least one) error. Zener diode CR37 (6V2) was shorted. I replaced it, put everything back and, voila - car works! :) I have tried to reproduce problem but was not able to. So It seems that the problem is finally resolved.
It was just 02.15h :) so I examined donor board and found mechanical damage. Can someone tell me the component markings for CR46 (diode, probably a zener type)?
[attachment id=0 msg=694420]
[attachment id=1 msg=694420]
//Marin
Hello Marin,
Nice work with repairing the chopper unit!
I bought a Citroen Berlingo a few days ago. And it might have a similar fault. I'm getting these errors from Checkelec:
Permanent fault - Speed sensor
Do you think both these errors could be related to the Zener that you replaced?
What's the easiest way to open up the chopper unit and have a look at the PCB?
