Sv: Elbiler må få høyere engangs- og årsavgift enn bensin- og dieselbiler
Startet av Arunav, torsdag 19. oktober 2017, klokken 13:18
Arunav
Is it possible to charge Leaf in Tesla supercharger as both use Mennekes Type 2 socket?
Espen Hugaas Andersen
No. The Leaf only has Type 1 and CHAdeMO. Even if it had Type 2 it still wouldn't be possible to charge it at a supercharger. Only Teslas can be charged there.
Model X 100D.
Cybertruck reservasjon.
Arunav
The new leaf has a Mode 3 Type 2 connecter same as Tesla EU uses. Tesla US has a proprietary connecter. So physically it will fit but I am not sure if it can do the handshake and charge.
If the new Leaf has a Type 2, it can be plugged in, but it can't be charged. Only Teslas are supported.
Tesla could allow other car companies access to the supercharger network, but it would require additional hardware and software in the cars.
Model X 100D.
Trekkoppbil
I think nobody else than Tesla is running DC over the Type 2 connector.
TB
Renault Zoe uses the Type 2 connector up to 43 kW thru DC AC on the first modell.
(Edit: This was of course wrong, it should be AC - not DC.)
Lørenskog
3irikur
Nissan Leaf Acenta 2014 - Solgt og levert når Amperaen kom
Blå Ampera-e 2017
Yes, that's three-phase AC. I think Tesla is the only one doing DC over Type 2. The standard does however support DC over Type 2, but only up to 70 kW. Tesla has tweaked the standard a bit to allow for 120 kW.
Model X 100D.
Sitat fra: Arunav på torsdag 24. august 2017, klokken 23:25
Type 2 is AC charging, Tesla has a proprietary charging solution which allows them DC. If the Leaf will follow the standard like VW, BMW etc. the DC charging will use the coms via type 2 socket and charge via two pins beneath the type 2 socket (CCS/combo), and it will not work on Tesla SuC.
Rav4_EV
Arne Magnus Berge 90608080
Daglig leder hos Euromatic AS folkeladeren.no
Sitat fra: Rav4_EV på søndag 27. august 2017, klokken 09:33
Type 2 is not only AC charging!
Per definition, but can you name any car but Tesla that utilizes DC through the type 2 socket?
As far as I understand Tesla uses a modified version that supports 240A/500V = 120kW instead of the 70kW limited standard, which means it is a proprietary type.
The lower one on that illustration for DC high is CCS/Combo, which supports a higher rate than type 2 (100kW at 500V).
Sitat fra: gr på søndag 27. august 2017, klokken 10:11As far as I understand Tesla uses a modified version that supports 240A/500V = 120kW instead of the 70kW limited standard, which means it is a proprietary type.
I believe the superchargers are 330A/500V, so 165 kW max. But the battery pack max voltage at under 70% SOC is more like 360V, so 330A x 360V = 119 kW.
Model X 100D.
Charge rate depends on the voltage out from the charger, not the battery state. I have never seen any information that SuC delivers more than 120kW (at 480/500V). Any sources?
Its interesting because competition are apparantly now starting to build 150kW chargers...
Sitat fra: Espen Hugaas Andersen på søndag 27. august 2017, klokken 16:35
The label in the SuperChargers say 410V maximum, not 500V.
Sitat fra: jkirkebo på søndag 27. august 2017, klokken 21:46The label in the SuperChargers say 410V maximum, not 500V.
I meant the connector. The supercharger electronics can't supply that much.
Model X 100D.
