Sv: Konstruktiv kritikk av Kona
Startet av Steens, torsdag 12. oktober 2017, klokken 08:01
#120
I did a small test while charging my Saxo today, measuring the DC chargingcurrent to the battery using several different measures. DC1 gives about 10A and DC2 gives about 30A directly to the battery.
Please observe the Info picture showing that my Saxo have different preg.ver's than my P106.
Steens
Thanks,
So it looks that the right scaling coefficient to apply is more something like 1.46 (rather than 1.41).
Btw, I observe also a charge at 14A and I'm very surprised to have an overcharge at 7A. I believed it was 5A according to the PSA docs and SAFT specs. Do you noticed the same ?
Sitat fra: Steens på onsdag 01. november 2017, klokken 11:03
Sorry, I did not have much time so only did the tests an recorded the vaules.
I will do the exact same "exercise" with my P106 soon, since it has different prog.ver., but I have to change some batteries first.
timescape
Thanks,
Hi Steens,
Did you notice my response last on page 8. :)
could scaling coefficient be 1,5 ?
Br.
Steens
Sitat fra: Elmo på onsdag 01. november 2017, klokken 12:34
Winter is coming, it's battery replacement time ;D ! (I also did some replacements last weekend :()
Sitat fra: timescape på mandag 30. oktober 2017, klokken 19:11
So can scale divide  0->150A.  ?
I always try to optimize the display on screen. The 150A was delivered by the PSA charge stations that do not exist anymore. I don't know people charging at 150A nowadays. I know that some people charge at 60A (Elmo) and read about some people charging at 80A. So I think it's not worth extending to 150A because for most of the people charging at 14A it will be difficult to see the difference between charge and overcharge (the difference will be just some pixels). So 2 solutions I can extend to a lower value (60, 80 ?). My favourite solution would be to be able to get the information from ECU if it is a fast or normal charge and then scale according to this info. I have not studied this case yet.
Sitat fra: timescape på onsdag 01. november 2017, klokken 13:34
1,5 is too much. Look at Elmo's values and try to find the best ratio between Checkelec and Lexia colum. 1,4 is not enough. 1,46 or 1,47 is good (we need more measurements to be more precise). 1,5 is too much : 29*1,5=43,5 vs 42 on Lexia.
As we are trying to scale an ECU data, it's important to take for reference a software reading the ECU data (Lexia, PP2000) and not another data source (Amp clamp, solenoid) as we don't know the error on this source. However, the external sources are useful to confirm the Lexia data (there could be a bug !)
Astepsy
<a href=https://fastpriligy.top/>cheap priligy</a> He was extremely supportive and compassionate with us, with our losses we had, he was very empathetic to that
Astepsy
amoxicillin presentaciones de ivermectina para humanos AhrendtsГў attraction to Apple is twofold firstly, her marketing prowess and ability to freshen up AppleГў s image, and secondly, her ability to use her deep emerging markets experience to market wearable technology to the emerging world <a href=https://fastpriligy.top/>paxil or priligy</a>
