Sv: Audi Q6 e-tron
Startet av Jeronan, onsdag 19. april 2017, klokken 15:36
Jeronan
Hi,
This morning we noticed that the wallbox was beeping with error blue/red/red/red bar.
The car's battery was down to 95% due to preconditioning on battery instead of wallpower eventhough connected.
Anyone had this error before on the wallbox? As this error code blue/red/red/red isn't mentioned in the troubleshooting section in the manual.
Model S 75D - Nov 2017
BMW i3 2017 - Feb 2017
SveinJ
ja jeg har opplevd det samme. Slå av sikring og slå den på igjen. det hjalp for meg. Tror dette står beskrevet i brukermanualen.
2014 BMW R1200GSA, Racing Blue
2016 Audi Q3 2,0 TDI, Hainanblue metallic
2016 BMW i3, FC, Mineral grey (solgt)
2019 BMWi3, FC, Imperial blue
Jeronan
Yes and that is what I did to solve it.
Just would have liked to know what the error means and thus the problem was, since this color code ( blue/red/red/red ) is not described in the troubleshooting section of the manual.
SveinJ
Dessverre er den feilen ikke beskrevet, så løsningen på "hva skjer 'a" er å bruke svenskeknappen = skru av alt  :P
Jeronan
The last week the error appeared 3 times, so I contacted the electrician via Bavaria, who had seen this problem with several other customers and sent me a new firmware update by email for the Wallbox.
I applied it this morning.  Fingers crossed it solved the issue.
SveinJ
Jeronan
Yes, but I got it by email from the Electrician who installs the BMW Wallboxes for Bavaria.
SveinJ
Jeronan
I think it was 3.07 or something.  Will double check tomorrow.
Jeronan
KEBA P30 v 3.07.1a1 (170111-112920)
Toalmar
Hei
Har dere kjøpt ladestasjon sammen med bilen?
Kan den ha utstyrskode ZWB?
BMW i3s 94Ah Fully Charged - 2018
Reservert TMYP Hvit / Svart 08.04.2020 - TMY LR Hvit / Svart 07.04.2020
TM3 LR AWD - Svart / Hvit - Solgt 01.04.2020
Jeronan
#11
Sitat fra: Toalmar på fredag 09. juni 2017, klokken 19:15
Hei
Yes we bought it together with the car at Bavaria Økern, Oslo. You then pay no MVA on the Wallbox and so save 25%.
No idea about that ZWB code? Where did you see that?
Since you have the same wallbox (saw it in your other topic), if you send me a private message with your email address, I can send you the update file.
Toalmar
Koden er funnet i prisliste fra BMW
Toalmar
Sitat fra: Jeronan på tirsdag 13. juni 2017, klokken 12:46
Hei
Da er endelig ladestasjonen blitt tilkoblet og testet. Er satt til 20A nå, men har 25A sikring så det er mulighet for at jeg stiller den opp. Ladestasjon ble oppdatert også. Takker for tilsendt fil, men denne ble ikke brukt da det ligger en fil på sidene til BMW som er enda nyere
