Sv: Helårsdekk
Startet av bno, søndag 26. februar 2017, klokken 10:37
Ipadjove
Diverse målinger i tommer. Og han sier plastikk-panser men det er vel aluminium.
Tom E.
I got my Bolt Premier will all options (MSRP $43,905) one week ago, I have driven it about 500 miles so far and it's time for the first review.
Some background.
I live in Southern California and the Bolt is my third electric car after a 2011 Volt and a 2014 Spark EV. My daily commutes varies from 30 to 70 miles round-trip. The 15 mile commute to my home office consists of a 1,000 foot total elevation drop, and a 600 foot drop in the first 4 miles. This condition has an impact on range which varied for each of the cars and has an interesting effect on the Bolt.
I am large at 6'1" with a 52 coat size so take into account on my comfort reviews. The temperature conditions this last week have been unusually cold for So Cal, with lows each morning in the low 30s and highs in the high 50s. Also it was raining for most of the time.
While not a professional, I have been setting up and driving race cars and high performance street cars for over 45 years so I have an understanding of vehicle dynamics and what makes things work (or not). I have also worked in physical, electrical, and computer/software design and testing fields so I have an understanding of those areas as well.
Range efficiency and battery:
The Volt and Spark both used the battery conservatively to be sure there would be enough charge cycles to maintain initial range for the warranted life of the battery. The system only allowed the battery to be charged to something less than 90%. This meant the when I left my house with a full charge there was room in the battery for additional energy from regeneration. I believe that first four miles of downhill allowed me capture that regen energy and charge the battery to a higher level than the software would allow from the charger. The effect of this was that I could get routinely more range than was advertised for each car. Several times I was able to get 50 miles electric only in the Volt and my lifetime average efficiency for the Spark at 35,000 miles is 4.6 miles per kWh (or 21.7 kWh per 100 miles).
Interestingly the Bolt seems to charge the battery to 100% and there is no room for regen energy with a full charge. I noticed this upon leaving my house on a full charge and both the L shifter setting and the paddle regen had no deceleration affect. I then changed the Hill Top Reserve setting to On – Home Only. The next full charge was only about 90% on the meter and the regen worked as expected. I will keep this setting as I like the strong regen and I will get better efficiency by using that gravity instead of wasting it through friction braking.
As for range, my initial results are not that good, but I spent a lot of time siting in the car with it on and the HVAC running in the colder temps so I will reserve judgement for better conditions. The last day of this one-week period the sun was out and the temps a bit warmer so I did see better efficiency with the heater off. Average for the first 500 miles is 3.6 miles per kWh
Driving impressions:
Driving and performance dynamics are quite good. Acceleration from a stop is impressive as the traction control system keeps the tires from spinning. The pull levels off as you approach freeway speeds, but is still ample for passing up to about 80 MPH. Handling is crisp, but due to the bad weather I have not been able to push anywhere near the limit. When the weather warms up and dries out I will set up my performance monitoring equipment and get some acceleration, braking, and lateral G cornering numbers. On first impression the friction brakes are adequate, but not as aggressive as I like and require a bit too much pedal pressure for a hard stop. This could just be due to new brake pads that are not bedded in yet.
Ride and Noise-Vibration-Harshness are also quite good, however keep in mind my references are a Corvette, Fiat Abarth, and Trailblazer, so I don't have a luxury car to compare it to. The regen to friction braking integration is amazing. With a little practice using the L shifter setting, accelerator pedal and Regen on Demand paddle, it is possible to almost never touch the brake pedal. This feature must be experienced to appreciate.
Comfort:
HVAC
Although the heater drains the battery at about 6-7 kW, it is much better than either the Volt or Spark, in fact it rivals that of ICE cars. The steering wheel heater gets too warm to leave on after about 2-3 minutes and the seat heaters need to be turned down from high after just a few minutes, so they are all working very well. Rating on the air conditioning will have to wait for some hot weather.
Driving position is good and it is easy to adjust to the correct seat and steering wheel position with the tilt/telescope wheel. However the lack of power seat adjustment is a problem. If the buyer wants power seats they should be available. I don't accept the explanation that power seats are not available as a weight saving measure. The variability in driver/passenger weight and cargo carried is far greater than the extra 10-15 pounds per seat the power adjusters weigh. If I am willing to give up a couple of miles of range to have power seats, that should be my choice.
Seats
The lack of power adjustment and the seat design are probably the only disappointments on the car overall. They seats should be fine for anyone with a 36" or smaller waist but the hard plastic frame is simply too narrow for anyone larger than that. The hard plastic frame is only 15" wide at the hips and sits up higher than the seat cushion. This design defect causes the seat frame to press uncomfortably into my hips on both sides. I wouldn't quite call it painful, but is does detract from the otherwise wonderful experience of driving this car. The worst thing is that this defect was completely unnecessary. There is over three inches of clearance between the outside edges of the seats and center console/door/frame pillar. This is an epic design/engineering failure that could easily have been avoided. It is almost as if whoever was designing the seat had the wrong interior dimensions of the car. This is something GM needs to fix or they will lose sales to larger frame folks. I am willing to put up with it until I lose some weight or find a modification to the seat, but many won't.
Tech and Infotainment:
I am still learning all of the features and capabilities of the tech this car offers so I may have missed something here. The tech and infotainment is mostly very good with a few quirks.
Cameras
The 360 camera feature is great for parking. The camera based inside rear view mirror works great in daylight and sees a much wider angle than the reflective mirror. Understandably it does not work as well in rain or darkness, so it is a good thing the automatic dimming reflective mirror is available with the flip of a lever.
Collision avoidance and lane departure
These features are interesting, but not yet reliable enough for me to completely depend on them. I keep both features ON. The collision avoidance sets off a beep and a bright flashing heads-up red light on the windshield. There is also a graphic of the rear of a car that changes from yellow to red as you get closer to the car in front of you. In enhanced display mode there is a setting that shows the following distance in seconds. I have not, and will not, test the automatic braking to see if it would stop the car before a collision. Perhaps with a cone/paper/Styrofoam mock-up, but not with a real car or obstacle.
The lane departure feature seems to need some work. When it was safe on a multi-lane road with no cars around me, I tried letting go of the wheel. As the car drifted toward the line the indicator changed from green to amber and the text "Take the Steering Wheel" appeared. As the tires got on the line the computer turned the wheel to avoid crossing over it, however it then overcorrected and took the car to the opposite side of the lane only to repeat the over correction. I did not allow the system to keep doing this as I was on a public road and did not want to alarm other drivers. As stated in the manual this is not a self-driving system.
The rear cross-traffic warning seemed to work well a couple of times I have the car in reverse and there was a car crossing behind me.
The Side Blind Zone Alert works, but has both false alarmed and failed to light. Most likely due to the heavy rain. The manual has several warnings that since these systems use a combination of cameras and sonar/radar sensors, they may not work in some conditions.
Infotainment
Overall these system are getting better over the years. Everything not related to a smartphone is intuitive fast and functional. For instance, the radio XM, AM, and FM has a virtual keypad to direct enter the station number or frequency. Audio and speaker sound quality are on-par for a car at this price point. I have not yet tried media on a USB drive works as well as any other.
As for smartphone integration, I have both an iPhone and a Motorola Z Force Droid. There is more functionality with Apple Car Play and Android Auto than in prior implementations, but there is still much room for improvement. Since this is the only system with these features I do not know if shortfalls are a GM/LG issue or more related to Apple iOS and Android. The biggest issue is the limited number of apps available. It seems Apple will only allow a subset of native iOS apps to work. Android Auto has a few third party apps available, but certainly not everything on Play Store. If the reason is a code issue that requires additional programming for a given app's screens to work on the car display they need to work on making that a pass through. If it is some misguided form of control, that makes no sense since you can just put your phone or tablet on an in-car mount and run any app anyway. The changeover between Apple and Android is a bit cumbersome. You have to manually change the Bolt settings to turn off one and turn on the other before you plug in the device. It would seem there could be an automatic prompt when you switch devices asking if you want to change. The programmers must have thought users would only have Apple or Android and not require switching back and forth. Lastly I can't believe both of these implementations require plugging the phone in with a wire! The car and the phones all have WiFi after all.
Overall, I am very pleased with the Bolt and glad I got one. I would recommend it to anyone. This is a brand new model with many new concepts just coming out of development. The critical items I mentioned are in the interest of fostering improvement, not to complain. More to come as I get to know the car better and log more miles in different conditions.
Ikke et ord om kvaliteten på kassettspilleren?
Ipadjove
Gamechanger. Teslarekkevidde til Leaf-pris.
Ipadjove
http://www.surfer.com/blogs/surfer-approved/2017-chevy-bolt/#qmRfA6JhzfMkRUIk.97
Petrolhead som ikke vil kjøre bensinbiler mer etter å ha prøvd Bolt. (Om jeg forstod rett.)
knut3448
En som har kjørt fort i minusgrader
http://gm-volt.com/forum#/topics/275697?page=1
Han startet med 87% og kjørte 163km. Estimert gjenværende rekkevidde var 83km, totalt teoretisk  246km. Teoretisk  282km fra 100% batteri. Og dette var i temperaturer ned mot -7,god varme i kupėen, ingen forvarming og endel kjøring i 120km/t. Veldig bra resultat som jeg håper stemmer  (:
knut.aulie
Om seter (virker som modifikasjon er mulig);
The front seats have definite issues for many, including my wife and other passengers, and are currently getting modified with some extra high density foam in the lower lateral bolsters, lumbar, and upper lateral bolsters. If you are small or medium frame, this may not be as necessary for your spousal satisfaction, but your rib cage and cheeks are essentially touching the hard plastic frames. I'm not overly picky about seat comfort, and even I'm not sure how they got these seats out of committee. Don't sign for a Bolt until you've sat in one. Luckily it's easy enough to modify. The seat mods I'm doing don't impede at all on interior space, or airbags, and add less weight than I removed from the ridiculous foam space waster they fill the non-spare tire well with. You can see in my pic the spot that's most uncomfortable for standard sized Americans, along with the middle of your rib cage.
jodd
___________________________
2018 Hyundai Kona - avbestilt
2019 Tesla Model 3 - levert 01.03
S4e
Tesla Model 3 LR AWD FSD Hengerfeste
Ecolite ladestasjon
Ipadjove
En som har testet og kjørt neeeeesten tomt batteri. 48 mil.
Gnilre
Interessant video, men 42kW ladehastighet er jo litt sløvt. Med litt enkel regning finner jeg ut at en grei strategi når man er på langtur blir å kjøre bilen ned til ca 20 % batterikapasitet, og så stå 42 minutter å lade for å få batteriet opp til 70 %. Da kan man om sommeren kjøre ytterligere ca 200 km i Norge (regner med 400 km reell rekkevidde sommerstid) før batteriet er ned på 20 % igjen og man må lade nye 42 minutter. Greit nok, men det beste hadde vært om bilen kunne ta mye mer enn 42 kW og at ladehastigheten også holdt seg litt bedre over 70 % batterikapasitet. På den annen side betyr jo dette at jeg om sommeren når hvor som helst i Norge minus de fire nordligste fylkene på kun ett ladestopp  :)
Kia Soul EV sept 2014 - aug 2016. Fin langturbil !
Opel Ampera-e levert 19.mai 2017 og solgt november 2017 etter 12.000 km. Beste bilen jeg har hatt.
Vil ha en 4-hjulsdrevet litt stor elbil. Vision eller EQC ?
Ikke dårlig. 482km, og bilen meldte om 20 miles restrekkevidde 5 miles før han startet filmingen.
Det betyr altså at når du har under 25km restrekkevidde vil restrekkevidde i displayet forsvinne.
Det gir en total rekkevidde i dette tilfellet på ca 507km.
Men skuffende hurtiglader-hastighet ja. Denne bilen burde støtte 70-80kW makseffekt. Forstår ikke hvorfor GM har gitt den så dårlig hurtigladehastighet?
Mercedes EQC AMG 2020
Model Y Performance bestilt
x Tesla Model X90D 2016
x Kia eNiro 2019
x Tesla Model S 90D 2016
x Nissan Leaf mars 2012
x Model S aug 2013
knut3448
122Wh/km på den testen. Utetemperatur på 15-20*C og  ingen bruk av klima/varme. 1/3 av turen på motorvei i inntil 100km/t. Resten bykjøring.
Ganske optimale forhold, men fortsatt mulig å få forbruket litt lavere. Interessant test. Nå venter jeg bare på at noen tester hurtiglading på 175-200A lader.
Motorvei i 100 og deretter bykjøring gir nok en del høyere forbruk enn kun jevn landevei i 70-90, noe som er situasjonen i store deler av Norge.
Må si denne bilen imponerer med sin rekkevidde. At han under disse forutsetningene kom så tett opptil NEDC er overraskende, men ikke sjokkerende mtp. de andre erfaringene som er lagt ut.
x Kia eNiro 2019
x Model S aug 2013
knut.aulie
Sitat fra: Gnilre på søndag 05. februar 2017, klokken 13:33
Hvordan fikk du 42 minutter fra 20-70% når han i videoen gikk fra 0-50% på en halv time ?
zbk
Sitat fra: knut.aulie på søndag 05. februar 2017, klokken 18:08
42kW ladeeffekt gir 30kWt (50%) på 42min...
