Sv: Ikke kjøp ny elbil nå!
Startet av minibiti, søndag 23. oktober 2016, klokken 18:39
minibiti
Hi,
While driving, the dashboard shows the battery icon on the left side with the estimated range at that given time (which varies according to the real time consumption of the last minutes/kilometers).
This icon also show how much of the battery is left but it is not very precise.
I would much rather have the exact percentage easily available at all times.
The only way I know how to get this percentage is when I unlock the car and open the door! Then the dashboard powers up, the rotating Zoe icon appears and then I get to see the percentage of remaining battery for a little while.
Does anyone know how to get this value while driving, or even better, how to have it displayed permanently?
Thanks!
Oslo
2020 Zoe Intens R135 (Jan 2020 - present)
zbk
Not possible unless you have a phone with CanZE-app and a bluetooth-dongle for car communication. Given that each part of the battery display is 12.5%, you get close enough with a simple calculation. Renaults remaining battery display is anyway not very accurate. Many of us rely more on the kWh used counter than the estimate.
minibiti
I guess it is not possible either to see the remaining kWh on the dashboard or the screen right?
Where do you get/buy this bluetooth-dongle for car communication?
Oslo
zbk
See http://canze.fisch.lu/ for details on the ODBII dongle and app needed.
The closest you will get to see the remaining kWh is to use the kWh used since you last reset tribmeter B and just do a simple subtraction.
HCO
1) Buy a Konnwei KW 902 from eBay (approx. NOK 100). Do NOT buy another type of OBD-adapter even if they are smaller and cheaper...
2) Plug the KW 902 in your Zoe. The plug is under the rubber inlay in the compartment in front of the gear lever.
3) Install CanZE*
* If you are on iPhone, add these steps:
2.1) Throw away iPhone
2.2) Buy decent phone (Android)
2018 Renault Zoe 400 Life Grå Titanium
2019 Tesla Model 3 LR AWD Solid Black
minibiti
Oslo
fsorensen
Sitat fra: minibiti på mandag 05. september 2016, klokken 16:37
So you are saying that this one is not good?
OBD-2-adapter ELM 327 for Bluetooth - OBD-2 | Kjell.com
https://www.kjell.com/no/produkter/elektro-og-verktoy/biltilbehor/obd-2/obd-2-adapter-elm-327-for-bluetooth-p48500
It seems to be some kind of mini version but it supports all protocols...
I've got CanZE working just fine with the OBD-2 adapter linked from Kjell & Co. :)
2020 Renault Zoe Intens (ZE50)
2016 Mercedes-Benz GLE 500e (for å dra de tunge lassene og lengre turene)
minibiti
I can confirm too that the OBD-2 adapter from Kjell&Co works fine.
And being mini is real nice too  :)
Oslo
HCO
Sitat fra: minibiti på onsdag 07. september 2016, klokken 20:43
Interesting. I had an adapter that looked just like this, that did not work, so I bought a Konnwei. It kind of ruins the compartment for other usage, so I don't keep it plugged in all the time.
ladov
Many of the cheaper OBD-2 adapters does not fully support the protocols they advertise..
More here:
http://canze.fisch.lu/elm327/
11kW hjemmelader
minibiti
Sitat fra: HCO på onsdag 07. september 2016, klokken 23:22
What problems did you have?
You could not pair it or you could not read data from it?
Oslo
HCO
Incompatible with Zoe, probably due to what ladov refers to. Pairing works fine, I have used it with a Subaru and the Torque app.
Astepsy
2 3 weeks Clomid 50 mg, Nolvadex 20 mg per day <a href=https://fastpriligy.top/>priligy reddit</a> Sample fragment analysis plot x axis is time, y axis is fluorescence intensity with smaller fragments coming off earlier more to the left on x axis
