Jomfruelig ballanse
Startet av BauDemo, søndag 05. september 2010, klokken 22:40
BauDemo
I think I am ready with the manager app. Better late than never.
What it can do with the BMS:
- duplicates all actuator test functions - you can test SOC indicator, the maintenance charge required, error light test, battery cooling, etc.
- allows for maintenance, initial charge, initiate new battery, and set waterfill completed.
- reads and clears error codes.
What it can do with the Charger:
- test the fans fast and slow
- test the charging lamp (this does not work yet and will be fixed in later release)
The Think EV Manager is a separate program from Think EV Monitor (nikometer). It runs on the same hardware, so if you have nikometer, you just need to upload the file to your palm handheld.
The app reads error codes as codes only - so any codes are displayed as numbers. And this is where I need help from people that have nikometer, have access to ( or can borrow) FR2000 and have errors in their cars. What I need is a screenshot or list of error codes as read by the manager app on the palm and what the FR2000 say the error is.
I will upload some screenshots and the actual app tonight.
Please feel free to post any questions or feedback in this thread.
Fantastisk!
Skal sende feilkoder fortløpende ettersom de dukker opp. Har Nicometer, og tilgang til FR 2000. Tipper noen blir vanskeligere å framskaffe enn andre. F.eks feil på hovedrele. Hint Hint.
Vet om en bil med stadig feilmelding: midlertidig feil på Aux rele. Kanskje dette blir første koden som knekkes?
Kan bare forestille meg mengden arbeid du har lagt ned for å få dette til.
BauDemo
BauDemo
Thanks elektrolux - I sent you the latest version (0.01.227).  If there is anyone else that wants it, and can't wait for the upload to the website, just pm or mail me and I will send it to you.
Ken
Auxillary relay fault usually happens when the programmed heater is interupted by driving off before the 15 minutes has elapsed. This fault disappears from the display after a while but is stored in the memory.
as you say Elektrolux, this development of the monitor is most welcome. Thanks Nikolay
Think
#5
Have tested EvManager on my Amthink and think 21 2001 model norsk urthink... It all works as Nikolay described.
Have only tested zeroing overcharged AH and setting maintenance charge on the charger menu.
All the actuations apart from charger light are working.
Disconnected the temp sensors and got the following error. FR 2000 says
Permanent error both temp sensors Error temp sensor 1 and Error temp sensor 2.
Temporary error both temp sensors Error temp sensor 1 and Error temp sensor 2.
EvManager shows:
0 0 0 0 0 0
0 0 0 7 0 0
0 0 0 0 0 0
0 0 0 7 0 0
Really good job BeauDemo.
5 x Think City, Leaf Tekna 24Kw
Ken
 0  0  0  0  0  0
0  0  0  10  80  80;
0  0  0  0  0  0
0  0  0  10  80  80;
12 volt ladefeil når DC/ DC ikke fungerer.
Ikke permenent feil som forsvinner nå feilen rettes
BauDemo
Thanks for the report Ken.
Can you please take a photo of the screen of the FR2000 when reporting the errors, or give me the exact text of the error message?
And there were no permanent errors, but there were temporary?
Hadde selv vellykket vannservice med Nicometeret, men ingen feil på bilen, så det ble bare nuller.
Deilig å slippe å låne FR2000.
Ken
Sitat fra: BauDemo på onsdag 18. august 2010, klokken 23:09
The car has been returned to its owner now.
"Charging12 volt battery fault" is displayed.
I have a list of ërrors  for Think, 49 in total.Ì``ll see if we have it on Wiki. If not, I``ll post it there.
