Sv: Ladeplasser
Startet av HHF, mandag 04. juni 2007, klokken 16:56
cs
Hej Robort.
You told me about the Idea of switching off auxilary chargers if the onboard charger wents to equalisation phase or does a charge break as in the new Think.
If more guys here are interested maybe it is possible to do a partslist and a wiring scheme and some larger Pics into the Elwbilwiki.
I would love to have such a Master Slave box for more than one Phase.
In my City EL I work with a simple Master-Slave 1Phase plug, because the 2 chargers together can work on one phase. But this is of no use for a bigger E-car where fast(er) charging always means additional 230V or even 400 V 3 phases.
Chris
2x Peugeot Scootelec, City EL (running), Th!nk City 1299 returner (sold), Th!nk City Gen2 Zebra EX-Ambulance 2008 1PP-2 Prototype Series, Kewet Citi Jet5
DE-52XXX near Cologne
http://www.thinkers.24.eu/
http://www.evalbum.com/3418
BauDemo
Totally off topic, but I could not resist.
Chris, if you change the regional settings on the palm (to US) so the decimal point is a point instead of comma - then the background colors will suddenly start working.
Nikolay
Sitat fra: cs på torsdag 17. mai 2012, klokken 21:06
Hi Robort.
I used the onboard charger in 10 A setting, a Zivan NG3 and 3x50V rectifiers in a row.
Together this is 48-49Amps.
I spoke to Gero already about the problem, he thinks with lithium temperature is less an issue as with NiCd even if he overvoltages the system, the currents drawn are much lower.
Chris
hens
Hvis noen får problemer med for dårlig kjøling på Think Classic, forsøk lufting av radiator.
Ta bort grillen, og løsne bolten oppe på endestykket på radiatoren. 5 mm bolt 8 mm sekskant.
vent til det ikke bobler lengre, og trekk til skruen FORSIKTIG!
Kan hende det er nødvendig å løsne lokket på reservoaret, hvis det er undertrykk i kjølesystemet.
olehenrikfjeld
Sitat fra: hens på søndag 20. mai 2012, klokken 20:40
Et par spørsmål til dette:
1) Hvor lenge venter du etter at du har skrudd opp lufteskruen? Jeg har ventet i kanskje fem minutter, men det kommer ikke noe kjølevæske fra pluggen og jeg hører ikke noe luft som slipper ut heller. Tett plugg, kanskje?
2) Skal sirkulasjonspumpa gå eller stå stille når du lufter radiatoren?
Jeg har plukket av hele grillen foran i håp om å forbedre kjøligen nå i varmen, men synes kjølesystemet sliter veldig med å få ned tempen.
Nå: USA LEAF 2012.
Før: Think City "Classic" 2002.
hens
Det kan være undertrykk i kjølesystemet, da kommer det ikke væske.
Løsne lokket på reservoaret, og prøv igjen. Ta IKKE ut skruen, bare løsne den, luften vil da komme ut i gjengene. Når luften er ute, kommer det frostvæske.
El rayo
Sitat fra: olehenrikfjeld på torsdag 24. mai 2012, klokken 20:59
Samme her. Med mye kjøring  4 dager i strekk i løpet av EV2012 krøp temperaturen opp fra 23o til 38o under en drøy times pen (under 100A) kjøring. Fant skygge i sommervarmen hver gang jeg parkerte.
