Quickcharging
Startet av BauDemo, mandag 26. oktober 2015, klokken 10:03
BauDemo
So here is the idea...
The idea is similar to the quick charging for the Clio.
To use a current-relay that senses the AC current that is used in the built-in charger and then if that current is higher than 5A, we start and run additional 3kW or 6kW chargers that have their DC output connected via the PCU connector for the air conditioning.
The car can be modified to a Type 2 inlet, and electrically retain all the cables, but the extra 2 phases can be connected to 2 3kW chargers.
6kW @360V is 17A, and the Air conditioning fuse is 20A.
Any reasons why the above should not work?
Go-carter
It has been done, on a Swedish lithium Think.
The Zebra-battery cant handle quick charge, as it heats too much up.
TMX60D
Leaf S 2015
Warlock
Good idea, specially for the Lithium Thinks. I'm not sure tho if the controller circuitry of the lithium-pack would be able to control and adjust the right amount of power going into the batteries...
BauDemo
#3
Guys... You need to get your facts right...
Edit:
Where do you get this info from?
Check here for example about a 1C charging untill 80%.
http://www.gunnarmusan.de/Material/Advances%20in%20ZEBRA%20Batteries.pdf
1C charging means charging with 27kW.
I am proposing charging with 9kW, which is 1/3 of the 1C rate... so there should be no significant issues with temperature.
Go-carter
I remember someone else talking about zebra not beeing able to quickcharge. I have no ide where that is stated. If you can quick charge the Zebra as well, I will be one of your first customers ;)
However, the swede that has already got this working, is this one:
TMX60D
Leaf S 2015
Warlock
#5
I'm not wondering if the Lithium battery can take it (nor the Zebra)
I'm wondering if the controller will be aware of the additional power, and adjusting the charge accordingly in spec with the charge-profile of the battery. I guess it could charge fine up to 80% tho, usually that is as much power as you can get....
For the Zebra, I've heard rumors (on this forum) that Think disabled 16A charging due to heat-problems. The battery can probably take the additional input power, but it might be hotter than comfortable.If this heat-problem is true I do not know tho...
Go-carter
16A charge was "disabled" (the pulled out the powercharge-button in the charger cable) due to other reasons, it was never removed from the PCU2-cars afaik. I use it often :)
The blue Think mentioned above, uses three original think-chargers. I dont remember who produces them, and afaik they were quite hard to get hold of. But I suppose that the charge-profile is the same for all three chargers, and should not harm the battery.
TMX60D
Leaf S 2015
VWspirit
Gen 2 bruker Eltek lader. Skulle tro disse kan paralellkobles på can-bussen
Bosted:Steine, Vestvågøy...*Heggedal, Asker
Jaguar I-Pace 2019
Tesla S100D Pearl White 2019
Think 2011 Sort 2+2 Li (bygd om fra zebra)
*Think 2009 Sort, Li (bygd om fra zebra)
*Think 2002 Sort, 3x25A 230V hurtiglader
*Citroen Saxo 2002 Blå met.
*VW Golf Citystromer 1998 56600km
BauDemo
Yes, Gen2 uses Eltek, but a special eltek for Think only.
Now who can tell me more about this http://archive.is/wm0IK
Fast charging in 15 minutes.
VWspirit
Sitat fra: BauDemo på fredag 30. oktober 2015, klokken 23:32
Do you have any documentation that the Eltek is special made for Think?
http://www.evolveelectrics.com/PDF/Eltek/Eltek%20Guide%20IP20.pdf
Jaguar I-Pace 2019
Stromskap378V
Hei, er denne avhandlingen om AC hurtiglading  kjent?
Fast-Charge_using_AC
http://udel.edu/~jsj/JSJ-EV-AC-Fast-Charging-Thesis.pdf
Implementert i Renault ZOE.
På side 48/133 også vår TH!NK oppstår.
Ha det gøy og litt hodepine mens han studerte.
HANS
TH!NK City / Okt 2011  Standort: Deutschland / Tyskland- Berlin
YYCAD2MC4AU ... (25kW Motor, EnerDel-Batt., 2010 Finland)
Do not speak norwegian. For translate I use maschine translators.
Operativsystemet Linux_openSUSE og Debian)
