SpaceX - DSCOVR Launch
Startet av satheesh.net, søndag 08. februar 2015, klokken 16:54
satheesh.net
SpaceX's customer for the DSCOVR mission is the United States Air Force, in conjunction with NOAA and NASA. In this flight, the Falcon 9 rocket will deliver the DSCOVR satellite to a 187 x 1,241,000 km orbit at 37 degrees. The DSCOVR launch window will open at approximately 6:10pm EST on Sunday, February 8, 2015, from Space Launch Complex 40 at Cape Canaveral Air Force Station, Florida. If all goes as planned, the DSCOVR satellite will be deployed approximately 35 minutes after liftoff.
DSCOVR Launch on Livestream.com
http://new.livestream.com/spacex/events/3783845
Amoss
... og ikke minst ett nytt forsøk på å lande 1. trinnet på "Just Read The Instructions" :)
http://www.nytimes.com/2015/02/08/science/goresat-is-set-to-launch-on-spacex-rocket.html?_r=1
SitatThe satellite will ride to space atop a Falcon 9 rocket built by Space Exploration Technologies, or SpaceX. The launching gives SpaceX a second opportunity to try to land the first stage of the rocket on a platform in the Atlantic Ocean, a step toward reusable, and potentially much less expensive, rockets.
Last month, in the first attempt, the Falcon 9 booster could not remain upright as it descended. It exploded, but caused only minor damage to the platform. Elon Musk, SpaceX's chief executive, said that the rocket had run out of hydraulic fluid and that more would be loaded this time.
Ellers går artikkelen ut på mer bakgrunn for satellitten og dens oppdrag.
Model S 85D
Leif1
Konvertitt fra S til X
Og det ble en ubetinget suksess!
Helt utrolig å se sekvensen der 2 bæreraketter lander simultant omtrent på 5øren, og når skjoldet rundt Tesla Roadsteren sprenges av og en ser vedlagte bilde.
Lassi
DSCOVR var i 2015...
Falcon Heavy som ble sendt opp i går.
Ubetinget suksess var det heller ikke, 3dje boosteren gikk i følge BBC tom for fuel før den fikk bremset ned nok til å gjennomføre en kontrollert landing.
Men heftig show! Ikke minst en enorm markedsføringverdi i en Tesla med live kamera feed fra verdensrommet...
mthoring
Sitat fra: Lassi på onsdag 07. februar 2018, klokken 08:52
Mislykket landing av senterboosteren er en tilnærmet ubetydelig bagatell, da den ikke var planlagt gjenbrukt uansett. Det at de etterhvert mestrer landing og gjenbruk av den også vil jo selvfølgelig være bra for økonomien i selskapet. Men det er vel ingen som tviler på at det kommer til å skje, siden det nærmest har blitt rutine for dem med førstetrinnet på Falcon 9.
Slik ståa er nå kan SpaceX underby alle med god margin, også på heavy lift uansett.
Det som virkelig betydde noe ifm Falcon Heavy oppskytningen var clearing av launch pad, oppnåelse av stabil bane, retenning av andre trinn og plassering av payload i heliosentrisk bane.
S75D MCU2/HW3 - prod 27/8/17
Mii Electric - utlevert 08/20
mthoring
