Indicator shows 0%, charger won't start
Startet av eltransbg, torsdag 20. februar 2014, klokken 08:02
eltransbg
Hello,
I searched for similar topics, found one.
But didn't understand the solution and opened a new topic.
Our Partner shows 0% of Energie...
We plug-in the socket and the charger starts for about 10-15 seconds.
The batteries shows 3,27-3,28V - all cells.
The batteries are one year and a half old, LiFePO4 type.
The total voltage is 159V.
We do not have the testing computer.
What is the solution of this problem?
Thank you!!!
Could be a bad contact in one of the batteries. This will prevent the charger from starting, as the voltage will increase to fast once current is flowing.
eltransbg
Sitat fra: elektrolux på torsdag 20. februar 2014, klokken 09:30
Thank you!
But unfortunatelly this is not the problem.
This saturday the charger degnited to start at all - even non for 15-20 sec.
The problem looks is somewhere else.
When we have 0% on Energy, what we should do?
Ciumpalac
Sitat fra: eltransbg på mandag 24. februar 2014, klokken 10:30
Unfortunately, I can't help you with problemsolving, but I can tell you that NiCad batteries can be stored for a long time at fully discharged state, so no immediate danger there...
Bor i Asker, har 2002 Saxo med 62800km, og en 2011 Peugeot iOn
Sitat fra: Ciumpalac på mandag 24. februar 2014, klokken 13:32
Wasn't this Lithium ??
Sitat fra: eltransbg på torsdag 20. februar 2014, klokken 08:02
eUp 2014 - solgt.
Ciumpalac
eltransbg
Yes, batteries are lithium 160Ah...
I think the batteries are not the main problem in this situation...
Have to figure what to do with the car.
In December we changed the motor with newer one, again from Partner.
Now this problem - it is awful...  :-\
I have very little experience with Li-converted PSA-classics, but in my experience there are so many slightly different ways to do the conversion so I think you need to contact the company or person that did it.
Some control-questions anyway.
- has the SOC meter worked before? (several conversions I have seen it does not work)
- are you using the original PSA-NiCd charger? (some do, some install a new one)
eUp 2014 - solgt.
