Power limit .... Nightmare
Startet av JVP, tirsdag 03. september 2013, klokken 12:29
JVP
I need some help with my Think 2010, power limit blinking, on instrument panel battery charged 100%, but its not start at all. I check with some Bosh KTS diagnostic equipment that is one error, only in Zebra battery module
30210-system error.
and its not eraseable....
Battery become hot when is connected to extend power few days, but even when is hot power limit still blinking.....
Please... Any clue...
JVP
Uff, after very long searching I fix this, pity that I had no help from here, I'm technician electronic and after some investigation I get the problem solved
Regards to every th!nk owners
Tarpoon
We would appreciate if you told us how you were able to fix your problem.
I don't have your diagnostics tools, but I would be able to tell the guys at Røhne Selmer what could cause the trouble.
Think City 2011. Zebra. 2-seter. Sort.
Brun Tesla Model S85.
commiesoft
SitatUff, after very long searching I fix this, pity that I had no help from here, I'm technician electronic and after some investigation I get the problem solved
Why don't you just post the solution here then? To help other Think owners that could easily end up with the
same problem.. ?  unbelievable..  ;D
Think City 2011 Li, XEL Cruiser lett MC 2010, EVT 4000e scooter 2008, Eco ride Avenue City + Alprace Ecorus 2012  elsykler, gøtt humør :)
Sitat fra: JVP på fredag 27. september 2013, klokken 16:37
Pity you won't share the fix with us. We would have helped you if we could.
