Sv: Trist utvikling for Think.
Startet av El rayo, onsdag 17. august 2011, klokken 20:30
El rayo
...over FR-2000.
I've just read all relevant data, errors and started maintenance charge with the nikometer for the first time. No more fumbling around in the two line FR-2000 display. Four parameters are displayed simultaneously on the nikometer, complete with description. Additional three parameters shows data only.
With aid of the 4 function buttons I can read the data I want in 4 different situations, all user selectable. The selection takes a bit of time initially and over the years I have done small changes to my initial settings.  For BMS I've now chosen:
F1 driving parameters Battery voltage, Battery amps, Battery power outtake, Battery temp max, (Battery cooling, Battery Ri, Ah overcharged last waterfill)
F2 diagnose/quickcheck parameters
F3 fault tracing parameters
F4 charge parameters
