Sv: Nicometer i Nye Think
Startet av jim3cantos, fredag 17. mars 2017, klokken 21:21
jim3cantos
Hi, I have left the car outside in the cold for 3 days and when I came back it refused to start. Power limit flashing, some weird sounds and the symbol of the battery in red. The car doesn't charge either. I read 10v in 12v battery from OVMS and also windows go up and down very slowly.  From other threads I suspect (and hope) 12v battery is the culprit. Anybody has tried to recharge it using one charger/manteiner connected to the 12v outlet (cigarette lighter) or it should be better to connect directly to the battery? Does the procedure from the image below also apply to zebra Thinks when trying to access to the battery?
Thanks
jim3cantos
#1
...Good news. I came back this evening and that the car went "online" OK. I left it plugged this morning and it has charged from 60 to 85% even though it didn't begin to charge when I plugged it. I have just discovered that this one:
...seems to be charging the 12v battery when the car is plugged:
http://www.ctek.com/es/en/chargers/MXS%205.0
Only then?
cra
Yes, some users have upgraded their car with an external 12V charger to keep the 12V battery in good condition. It helps a lot in cases just like yours. :)
Tesla Model S75D 30/6/17
Leaf 9/5/12
Sykkylven (Sunnmøre)
Stromskap378V
Wow, I believe  that's a really good SMPS charger.
Prima also plug-in connector and different adapters.
It from 2V battery voltage works (Datasheet)? My device work only above 8 volts.
Cheers
TH!NK City / Okt 2011  Standort: Deutschland / Tyskland- Berlin
YYCAD2MC4AU ... (25kW Motor, EnerDel-Batt., 2010 Finland)
Do not speak norwegian. For translate I use maschine translators.
Operativsystemet Linux_openSUSE og Debian)
jim3cantos
Doesn't this charger (CTEK) come standard in every Think A306? I didn't put it there inside the hood. It came with the car.
