Sv: Husholdningslader trafoboks (gul) til salgs?
Startet av LN-YOV, fredag 04. desember 2015, klokken 20:52
LN-YOV
Hallo!
Mens jeg holder på med å montere inn en dieseltank for webastoen så oppdaget jeg til min forskrekkels at hele PCU en er løs!
Som det går frem av bildene så er alle (i alle fall de jeg kunne se) gummiopphengene ødelagt!
Er det noen som vet hvilen bil de kommer ifra?
Eller hvor man kan få tak i/eller tilsvarende!
Er "529.6500.E PCU ISOLATOR RUBBER" I delelisten!
Walter Nyberg
LN-YOV
Hmm! de viktige bildene kom hvist ikke inn!
LN-YOV
jur
Seen this on other cars too. I have installed a "similar in form, fit and function" replacement offered by the italian firm Vibrostop (vibrostop.it, see attached datasheet) in my 2008 Think. Net price for PGM 44-60 was EUR 9,60 apiece then, plus VAT, freight ... .
I hope this helps,
Jens-Uwe
LN-YOV
Thank you for the answer!
Ford in Sandvika did also have them, but at a price of 250 NKr for one!
I did feel that that was a bit steep, so I did manufacture my own from some industrial rubber I found at work!
BTW. I did this before you post, else I may have gone for the Italy-en solution  :-)
They maybe not as good as the original, but they holds the CPU firmly in place and will hopefully last longer than 70K Km/5 years! :-)
LN-YOV
