LED lamps for the courtesy light
Startet av BauDemo, tirsdag 25. desember 2012, klokken 20:37
BauDemo
I tested two different LED light bulbs today - both seem to work well.
As someone pointed out somewhere else the LED bulbs are light just slightly in off position due to the dimming circuit. The dimming seems to work fine.
Here are some photos...
Comparison between the original bulb (the yellowish) and the led bulb. The led bulb is slightly more powerful.
Comparison between the two types of led bulbs - seem to be the same power.
The two bulbs with the leds visible.
Edit: Links to the bulbs:
http://dx.com/p/44mm-1-2w-6500k-110lm-6-smd-led-reading-lamp-boot-lamp-white-light-bulb-dc-12-18v-pair-57524
http://dx.com/p/1-5w-41mm-16-smd-3528-led-65lm-white-light-for-car-67062
