Sv: Tesla aksjer
Startet av Poppe, lørdag 26. oktober 2013, klokken 13:36
Poppe
I think I have read somewhere that someone installed a gasoline heater instead of the standard elektric. I had that setup, as standard, in my old Renault Express and it worked great.
Is there somewhere a build thread with pictures describing this ?
Anything in particular to think about ? Or is it just a straight change between electric to gas ? I assume the water temperature coming out of any of the heaters will be about the same, around 80-90°.
Chevy Volt -12
Th!nk City -99
Th!nk City -08
Peugeot 107 -07
Chevrolet Corvair Convertible -64
Chevrolet Rampside Pick Up -61
Renault Kangoo 4x4 -05
i Göteborg
hma
There are several new-Thinks which have Webasto/Eberspächer running on gasoline/diesel.
My Think has a hybrid heater system, with one Webasto-gasoline in addition to the original electric fluidheater, capable of independent usage. Works well and makes the Think run a minimum of 150km per charge, 365 days a year :)
See this post http://elbilforum.no/forum/index.php/topic,4522.msg63162.html#msg63162
- Toyota Rav4 EV 2000 NiMH (06/2010), Tesla Model S75D (12/2018)
   (tidligere: Think Classic 2000 NiCd (06/2009-05/2012) - Think City 2010 Zebra (03/2012-10/2012) - Think City 2009 Zebra (05/2012-05/2014)  - Tesla Model S 2014 (06/2014-09/2017) - Nissan Leaf 2018 LE 40kWh (04/2018-12/2018) )
- Ariens AMP 24 to-trinns snøfreser 48V litium 52,5Ahr (10/2012) - Bosch Rotaks 43 Li-Ion gressklipp
Poppe
Thanks !
That was the post I was looking for.
How come you kept the original heater ?
Chevy Volt -12
Th!nk City -99
Th!nk City -08
Peugeot 107 -07
i Göteborg
hma
Sitat fra: Poppe på mandag 21. oktober 2013, klokken 06:52
Because it works well, it's cleaner and it causes less wear and tear from ad-hoc usage.
The range is not a problem in my daily usage. I need the maximum range during winter only a few times a month, that is when I fire up the fuel.
Poppe
Thanks Elbilmek
That looks like a neat installation.
I'm not a facebooker myself but I could see the front picture of the Think with open bonnet. I could also go back to the album but could not see any aditional pictures of this installation. Are there any ?
Chevy Volt -12
Th!nk City -99
Th!nk City -08
Peugeot 107 -07
i Göteborg
