Sv: Software problem?! Klarer ikke å resette
Startet av Haahov, søndag 08. desember 2013, klokken 14:14
Haahov
E-Niro 2019: "Evion"
Euro-Leaf 2013 med 6,6 kW lader: "Selma"
Eureka
Hei stemmer svakere motor 2013 modell detteThe first word that comes to mind when you step on the accelerator is not a good one: neutered. It's been a while since we've been behind the wheel of a Leaf, but it was immediately clear that Nissan has made some compromises here. The biggest drivetrain change is that the new motor has had its torque output reduced, from 207 to 187 pound-feet, thanks to revamped software code. This gives the overall system more efficiency and more range, 75 official miles from the 24-kWh pack, but the horsepower remains the same, at 107. It also makes the car feel a bit sluggish.
2013 Japan Leaf bygget Oppama plant
2019 Evalia 40 kW 7 seter
